I'm trying to learn Inventor so I can help my kids with their class at school. I trying to sketch a part with a hole toward the top of a cylinder. I want the hole to be 1/2 in. down from the top. The help topics I have viewed suggest placing a plane on the outside of the can and a point on that, then drill the hole at that point....I can't figure out how to place the plane.....Help!
Solved by Curtis_Waguespack. Go to Solution.
Hi b.degraff,
This link illustrates the steps to create a Tangent Workplane using an Origin plane:
Edit:
This animation shows it well also (credit to JDMather for the animated GIF file).
I hope this helps.
Curtis
