How can I set up my drawing to be when I bring in a hole table or have one already I can change the precision of ALL columns in the hole table???
Also how can I set up the template to already have this??
Hi rnewcomb,
Have a look at this link:
http://forums.autodesk.com/t5/Inventor-General/HOLE-TABLE-PRECISION/m-p/1675568#M204314
I hope this helps.
Curtis
is there a way to change the precision of the current ansi? IT seems everything is set up as current ansi
If you go to the link Curtis informed you of it should allow you to format this. Then your project file needs to be set to "Use Styles Library" to read / write. Once this change is made in the template IDW you choose the save option within the Stryles and standards area of the manage tabe you will write these changes to the design data folder.where it resides.
Don
