Good afternoon all,
I am trying to retrieve center og gravity in my assembly, I now already coordinates given by iporoperties, now i want to measure to that specific point, is it possible to do it? or to actually show the center of gravity in the assembly? I will appreciate a lot your help! thanks in advance!
Diego
P.D. I will attach the assembly file...
Go to View and under the Visibility Tab there should be Center of Gravity. Once clicked it may ask you to Update the Center of Gravity, click OK.
The COG is now displayed and you can then measure from a specific point to the COG X,Y or Z Plane Axis
