Hi group
in inventor 2013 simulation, if i had a see saw that is level and i applied a cube to one side it would tip, I would like to know the force created on the other side in the upward direction. how do i do this?
I assume it is with the output grapher but i am unsure of what to use any help?
regards Adrian
Hi Further to this, I have placed a tracer to an edge and in the output grapher I can get velocity, acceleration etc.. but i would like force in kilos, is this possible?
the see saw design is just for explanation purposes on this post, the idea is i want to be able to place a force feedback sensor on my designs to sense movment or strain in kilos.
regards Adrian
Is your simulation static or dynamic? If static, then you could place a constraint at the desired point, and once the simulation has finished running, you can check reaction forces at all constraints.
Cameron Whetten
Inventor 2012
Hi Cameron
thankyou for your reply, I am currently looking in dynamic simulation. when you say static is this frame analysis?
I would like to have feed back for force and also movement.
in some circumstances I will want to push designs to see limits so for an instance as a basic scenario to try and explain a simple situation:
to detect how much a beam will flex under load
if i lay a beam across two boxes to form a bridge , lets say the beam is 3mtrs long and the boxes are 250mm square and there is no actual constraignts or fixings it will be resting on the boxes.
I want to then apply a load to the beam and for ease lets say in the centre but on top. (this load will be in the form of another solid object so lets use a box and the weight will be set to suit the problem)
the idea being the beam will bend under a big load so the middle will go down and the ends will go up (pivoting on the box edges) I want to have a feed back in kilos and mm of the movment taking place A) at the point where the load is place and B) where the ends move.
or any other point i decide to set
In dynamic simulation i can attach a trace and use the output grapher but it does not give me force or movment, if i set constraints it will be fixed so no movement will be recorded?
and would i use the trace to also get feed back of movment in mm even if they are very small e.g 0.001mm resolution and up.
I look forward to any input on this.
regards Adrian
