Inventor Forum
following the centerline sectioning
10 REPLIES 10
Message 1 of 11
azott
678 Views, 10 Replies
Dear all,
I add my worked. this work is a penstock at the hydroelectric powerplant. Due to uneven ground so inclined penstock and have many elbows. in civil engineering drawing section is taken from the axis line. so we compare drawings from the axis of the cross section have to take. what can i do this?
Thanks for all
10 REPLIES 10
Message 2 of 11
mdavis22569
in reply to: azott
Yes ... You can follow the path of ... If you're not dead on like you want from the initial section lines made, RMB and edit (not edit properties of the section ) them in a sketch mode and center them to the pipe with dimensions...
Mike Davis
Message 3 of 11
azott
in reply to: mdavis22569
how can i this i don't understand
you say;
in section(create a any pipe) centerline and revalve create so hence the axial line will be. then what?
Message 4 of 11
mdavis22569
in reply to: azott
go to the view you want a section in: from there make a section on the path that you want the view to follow. Pull the view down and make the section. Then from there if it's not what you're looking for, Right Mouse Button on the Section Line in the parent view and hit edit. Edit the line as needed .. constraints. Then finish. I can't upload at work fortunately to show you exactly ..but http://a360.co/1k0xHuG
Mike Davis
Message 5 of 11
mdavis22569
http://a360.co/1pgaoTp http://a360.co/1pgasCC
Mike Davis
Message 6 of 11
azott
Dear michael,
thank you for all reply, but our section is in 3d sketch so I can not do what your say
Message 7 of 11
azott
in reply to: azott
This is my pipe. As you can see, this pipe has 3d sketch route so i'didn't section to route
Message 8 of 11
mdavis22569
in reply to: azott
Ohhh ... didn't know it was a 3d sketch .. that's makes it a whole different issue to solve. Honestly, I'm trying to think of a way to do this ... unfortunately I just can't see how to cut a section thru something that needs to be kept on so many various ways.
Mike Davis
Message 9 of 11
azott
Thanks michael your replies.
No one will help me please?
Message 10 of 11
azott
in reply to: azott
dear all's this very big problem?anyone help me?
Message 11 of 11
graemev
in reply to: azott
I can only think of two possible solutions:
1) Create many sections, each of a portion of the pipeline conforming to a single flat plane.
Or:
2) Create a new copy of the assembly and rotate connections so as to flatten the centerlines to a single flat plane.
