Dear Someone,
Can help me, how to filtering a part list use view by assembly drawing, with VBA editor or iLOGic code.
there is no class system in API for filter in partlist class use views filter.
i use autodesk inventor 2010, and get install use ilogic add-ons 2010
i want to get automation system for my inventor design.
Thx.
Ihsan Surahman,
You may want to look into the blog article in the below link for sample ilogic codes,
Hope it helps.
The URL that he posted was cut off. I think this might be where he was trying to get you.
Hi d_great_ice,
I'm not aware of a way to set the parts list filter programatically, but what I've done in the past is to set up a parts list style that has the filter pre-set in that style, and then change the parts list to use that specific style.
I hope this helps.
Curtis
'assumes a drawing document is active. Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument 'Set a reference to the active sheet. Dim oSheet As Sheet oSheet = oDrawDoc.ActiveSheet 'set a reference to the first drawing view on the sheet. Assumes it's not a draft view. Dim oDrawingView As DrawingView oDrawingView = oSheet.DrawingViews(1) 'define the insert point Dim oPlacementPoint As Point2d oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d (27#, 20.625#) 'create the parts list Dim oPartsList As PartsList oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint) 'set parts list to a specific layer oPartsList.Layer = oDrawDoc.StylesManager.Layers.Item("Visible (ANSI)") 'set parts list to a specific style oPartsList.Style = oDrawDoc.StylesManager.PartsListStyles.Item("Material List (ANSI) with Filter")
@Curtis_Waguespack wrote:I'm not aware of a way to set the parts list filter programatically,
If I may add to an old post, I have a question. Can the visibility of items in a parts list be controlled through iLogic? It's a poor substitute for filtering, but it might work for me if filtering isn't possible.
I'm also looing into this, filter would be awesome..
I could use this for following reason. I'm currently managing our materiallist external to inventor (so more people can access it). When i creat a first export there is no problem, but what i want is to make have a tool that can append to the already existing list.
So i want to export item x to y into my existing partslist.
Or if a revision is needed export item x and paste it over the old item x
Having a filter that limits my list would make this a more easy to make tool ( i think ).
