Inventor Forum
filtering partlist use filter View
6 REPLIES 6
1310 Views, 6 Replies
Dear Someone,
Can help me, how to filtering a part list use view by assembly drawing, with VBA editor or iLOGic code.
there is no class system in API for filter in partlist class use views filter.
i use autodesk inventor 2010, and get install use ilogic add-ons 2010
i want to get automation system for my inventor design.
Thx.
Ihsan Surahman,
6 REPLIES 6
VinodBalasubramanian
You may want to look into the blog article in the below link for sample ilogic codes,
http://forums.autodesk.com/t5/Autodesk-Inventor/iLogic-to-Sort-BOM-Renumber-and-sort-Parts-list/td-p...
Hope it helps.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
in reply to: VinodBalasubramanian
link does not exist.
Please help.
karthur1
The URL that he posted was cut off.  I think this might be where he was trying to get you.
Try this....
Curtis_Waguespack
Hi d_great_ice,
I'm not aware of a way to set the parts list filter programatically, but what I've done in the past is to set up a parts list style that has the filter pre-set in that style, and then change the parts list to use that specific style.
I hope this helps.
Curtis
'assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
'Set a reference to the active sheet.
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
'set a reference to the first drawing view on the sheet. Assumes it's not a draft view.
Dim oDrawingView As DrawingView
oDrawingView = oSheet.DrawingViews(1)
'define the insert point
Dim oPlacementPoint As Point2d
oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d (27#, 20.625#)
'create the parts list
Dim oPartsList As PartsList
oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint)
'set parts list to a specific layer
oPartsList.Layer = oDrawDoc.StylesManager.Layers.Item("Visible (ANSI)")
'set parts list to a specific style
oPartsList.Style = oDrawDoc.StylesManager.PartsListStyles.Item("Material List (ANSI) with Filter")
in reply to: Curtis_Waguespack
If I may add to an old post, I have a question.  Can the visibility of items in a parts list be controlled through iLogic?  It's a poor substitute for filtering, but it might work for me if filtering isn't possible.
I'm also looing into this, filter would be awesome..
I could use this for following reason. I'm currently managing our materiallist external to inventor (so more people can access it). When i creat a first export there is no problem, but what i want is to make have a tool that can append to the already existing list.
So i want to export item x to y into my existing partslist.
Or if a revision is needed export item x and paste it over the old item x
Having a filter that limits my list would make this a more easy to make tool ( i think ).
