I need some help on how to make the fillets goes the opposite direction.I want the fillets to round the edges not join the edges together
Rich
Looks like you are trying to do Mult-body solids.
When creating the Extrusion features select the New Solid icon in the Extrude dialog box.
I changed the extrusions to New Solids and Combined but the fillet still adds as Fillet 3 shows....how do i use the fillet to go in the opposite direction (fillet 3) or do i need a sketch & sweep cut
@richard_cirillo wrote:I changed the extrusions to New Solids and Combined ...
I have no idea what your design intent is.
Making as New Solid and then Combine seems to be an error in logic to me.
If you want them combined - then don't use New Solid.
I thought you were doing multi-body solids (an assembly of parts in one part file).
Can you post a classical 2D AutoCAD drawing or scanned hand sketch of what you are trying to do.
Nearly done
1. I made Extrusion 2 a New Solid and this then solved the Fillet 5 and Shell issue..This is what i wanted to achieve
2. See where Sweep 4 is used,I wanted the same result here as Fillet 5 did at the other end but i could not get the Fillet to work (0.5mm) so i tried with a Sweep but it did not go all around the shape (extrusion 1)..just the top was a sweep
What is required for this to work?
thanks,
Rich
