Inventor Forum
exporting to pdf or AutoCAD...HELP!
5 REPLIES 5
KFrankenberger
1628 Views, 5 Replies
For some reason when I try to export my current drawing to a pdf (or AutoDesk 2007 DWG for that matter) it won't do anything but show the export progress window and states Updated Views: 0/4. There is a bar which usually starts showing green slowly across it for "progress" , but that is not filling up with green, it is just staying blank and empty like no progress is happening. This goes on forever and so I stop and try again only to get the same result!
Any help on this would be appreciated!
In the past it has worked fine and on a small DWG file or a 3D assembly (not a dwg) it is still working.
5 REPLIES 5
dimes26
in reply to: KFrankenberger
Can anyone help on this? I'm having the same problem and it's driving me crazy.
Thank you
blair
Can you try a IDW file and see if it works
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
BriHecato
Has any1 find a solution in two years?
I got Inventor HSM 2015.
Have designed two parts - place them on drawing - saved into the IDW successfully - but when i try to save as DWG or DXF Inventor stuck at "Exporting" Dialog without any progress..
All views have icons in model tree with red line strike diagonally - I've read that is has something with "raster view" but I have restart PC and app to make sure that i don't place views in raster state but icons are still strike through with red line.
Can't get over it...
blair
in reply to: BriHecato
Just because the people never responed and marked the post as solved doesn't mean it's still outstanding.
1.) Check your Add-In manager in Inventor that all the translators are installed and active.
2.) Try logging in with a different user account, prefferably one with Admin priv.
3.) Post a screen capture with the "red" icons in the drawing browser.
Delta Tau Chi ΔΤΧ
I've encountered this problem too. I simply restarted the program. I think it has something to do with pages or models not refreshing correctly because when I reopened my idw fille, I had a bunch of pending page updates (lighting bolt icon). Hopefully someone else that searches this up can try this.
