Can someone please tell me what this error means and what's causing it and how to fix it? Thanks ... Chris
IV2010, editing a multibody part gives these errors:
1. No more memory available. Attempt to allocate 208 bytes of memory failed.
and
2. See attached.
This error is preventing me from saving or closing the program.
It could be a network error if you are saving to a server and the connection is lost. If not it could be a failing hard drive or a loose connection between the motherboard and hard drive.
@cadman777 wrote:what's causing it and how to fix it? .
ASM - Autodesk Shape Manager error - in other words can't create the geometry.
Can you save the file if you drag the EOP to the top of the browser?
If so, attach the file here.
Thanks for quick response JD.
Turns out the prgram crashed while I was posting this request for assistance.
It worked fine after restarting the program and opening the model.
I did move the marker above the offending feature just before it crashed.
It's happened to me before on other mb parts, but I had to figure out other work-arounds.
Thanks again ... Chris
