Inventor Forum
equal sides
11 REPLIES 11
Message 1 of 12
663 Views, 11 Replies
equal sides
Hi
I have a .ipt file attached of a shape in which the shape is correct except i cannot get the 4 sides all to meaure 40mm..2 sides measure approx. 26mm and the other 2 sides approx. 55mm...how do i work out the correct angles to get all 4 sides to measure 40mm or is there a better way to achieve the 40mm sides...
Kind Regards
GRyles
11 REPLIES 11
Message 2 of 12
The root of your problem is the definition of your work plane - the angle of that plane will determine the relative lengths of the sides.  Draw a sketch on the front of your block with a line dimensioned as shown and then create a workplane using that line and a point constrained to it's centerpoint (or either end - doesn't matter.
Then you'll have to project that same point onto the cut profile sketch and dimension from there.  See attached.
Message 3 of 12
Hi Mikah
I had a go using your attached picture.I attached the .ipt file ..i did not get the sides to 40mm but i did get them much closer then first attempt..is there something i have missed or made a mistake
Kind Regards
GRyles
Message 4 of 12
ravikmb5
check this2027i455E08B24349F619
Please mark this response as Problem Solved if it answers your question.
Ravi Kumar MB,
i7 860 Dell Studio XPS Win 7 64 bit 12 Gb RAM & HP Z220 SFF Workstation
Autodesk Inventor Certified professional 2016
Email: ravikmb5@gmail.com
Message 5 of 12
in reply to: ravikmb5
Thanks Ravikmb5
Yes they are 40mm sides except there should be a slope above the 4 cuts and not flat
thanks for the help
GRyles
Message 6 of 12
You are close - the only thing you need to do is delete the 53.319mm dimension in this sketch and, instead, add a coincident constraint between the point you projected and the line the 53.319 dimension locates (see green arrows).  Then you can adjust your dimensions in the first sketch (the two 20mm values) to achieve whatever length you want on the sides.
Message 7 of 12
Much appreciatecd Mikah
GRyles
Message 8 of 12
IgorMir
I can not see the actual part ( I am with IV2010) but it seems pretty trivial part to model. At least by the look at the picture provided. Here it is the part in IV2010.
Igor.
Web: www.meqc.com.au
Message 9 of 12
Hi Igor
That is good...thank you and appreciated....the only step i need to change is where the Revolution 1 uses a curved sketch i need it to be straight line...if using a straight line instead of the curved line will all the steps you use still work?
Again thanks
GRyles
Message 10 of 12
IgorMir
Since I don't know the exact design intent - here is an iPart which documents some possible scenarios. I think the member Part1-03 ( I left it Active) reflects what you are after.
Best Regards,
Igor.
Message 11 of 12
Hi Igor
That is what i am looking for.Thank you and appreciated
Greg
Message 12 of 12
IgorMir
Hi Greg,
I am glad it worked for you!
Best Regards,
Igor.
