I have a unique challange. I use my personal laptop for my CAD work at work. We are now setup with Vault 2012 and Inventor 2012 and we are setup to pull our Templates, standard files and content center parts from the vault. I have become so busy that I would like to do some of my work at home on evenings and weekends. Other than the obvious problems of having no life and working for nothing, I am having the problem of not being able to access templates or CC parts at home. I can store the CC and templates on my C drive but am not sure where to set Inventor to point to the files on my drive or if there is an easy to do so depending on where I am.
Thank you
Solved by dave.anderson. Go to Solution.
There are a few ways you could handle this. The simplest would be to leverage some technology to allow you to VPN into the work network or otherwise connect to the Vault Server from home.
The second (more low tech) option would be to use a different project file at home, such as default. You’d need to install Desktop Content on your machine, and copy all the Design Data files as well as your company templates local, and point the new “home” project to those locations.
The only thing you cannot control in the project is how Inventor is configured to use Content Center. You will need to be change the Vault Content to Desktop Content in Tools>Application Options>Content Center. Other than that, just switch your project.
The one thing that may complicate this is of your company keeps the Content Center files (the actual .ipt files) on a server. If they do then any assemblies you open would have file resolution issues as that location is not available. You’d also need to move any Content that gets created locally to this central repository.
