Inventor Forum
drawing accuracy
5 REPLIES 5
rajeshindi
247 Views, 5 Replies
drawing accuracy
Is there any way to set the drawing accuracy in INV2013.
Like not to calculate the points more than 3 decimals.
Thanks.
5 REPLIES 5
mpatchus
in reply to: rajeshindi
Do you mean for the dimensions displayed in the drawing?
If so, set your dimension style to the number of decimal places that you desire.
(or you can manually override each dimension by RMB)
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
ferrisb
On INV 2009, but it may be the same for 2013.
Format
Active Standard
Units
You can open the ipt and assy file in templates folder and change them there if you'd like.
rajeshindi
in reply to: mpatchus
Thanks for the reply.
I am talking about the drawing accuracy.  Like inv calculating accuracy.
not the dimentional checking.
I import lot of customer dxf files and convert in to solids.  Some times the lines are not joined with gaps like 0.005mm etc.  I want INV to ignore any gaps less then 0.01mm.  Is there any option of setting any para's.
Thanks.
nannerdw
I'd recommend fixing the files in AutoCAD before importing them (ACAD's "boundary" and "pedit" commands are very useful for this), or if they're simple enough, just recreate the geometry in Inventor.
mrattray
No.
The data has to be dead nuts corect.
Mike (not Matt) Rattray
