hi;
i am working in tube and pipe in inventor. some days ago i populate a route with
a specific style. now i created another route inside the same pipe run. because i wanted to use the same pipe style.
when i populate the new route. it shows me the populated route for 1 second. then disppear quickly. also there are no object( tube, elbow) in browser for the new route
windows XP professional. 2007
64 bit
inventor 2014
I am actually having a similar problem with tubes. I try to populate a tube run, it will preview for a second and thenthe route doesn't actually populate. No answers, but lend my support in desiring a solution...
Hi guys.
I've seen and experienced this before. I have no idea what causes it. Generally, for me, the fix has been (regrettably) deleting the failed route and re-doing it. I also usually shut Inventor down and restart it first. I know, not a great solution, but it gets the job done quicker than scratching my head and shaking my fist at the screen (I tried that too).
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Could you make a screencast of the issue and post it here? Is this issue occurring with a particular style?
Hi Chris
Was there ever a result for this issue?
I cannot the route to populate in a certain assembly file. It was working fine, then i deleted to route and began a new route and now will not populate.
I can populate the route in other assembly files.
Regards
Paul
As Nathan said, post a video, or at least some pics of what you are seeing. Best thing would be to post a simple assembly that is exhibiting this behavior (if you can reproduce it). It's very difficult to know what's happening here, just from the descriptions of a drunk man. 😉
Chris Benner
I haven't been able to reproduce this in another assembly.
See link attached:
http://screencast.com/t/7aF2H5mOi3
I cannot add assembly. Too large in size. And IP.
@Esky99! wrote:
No good.
Too get this route to populate I need to delete the substitute level of detail of detail.
May need to create a product support case on this one!
That might be the best approach, just in case it is a "bug" of sorts.
Chris Benner
Nate,
I am not sure that the situation I am facing with my user is the same as what KopexWaratah is seeing. My user seems to be having more problems with just the styles and randomly not being able to populate hose runs. Am having him perform a repair and reinstall to see if that helps, but he can just create simple runs with no substitute levels of detail and will still get the issue. Not sure if this helps, but wanted to provide some more information. Have an awesome and most blessed day!
Peace,
Pete
