Inventor Forum
dimensioning to Z shape implied intersections
2 REPLIES 2
333 Views, 2 Replies
Looked through the help and found nothing, then did a search here and found nothing.
I am needing to put a horzontal dimension from the implied intersections of a "Z" shape.
In the attached screen shot, I have a question mark at the dimension I'm needing.
I have tried the RMB/Intersection in different ways, but none giving me the dimension
I'm needing.
How do I go about getting this dimension?
Thank you very much for your help.
2 REPLIES 2
mpatchus
To accomplish this task do the following:
  1. Select Line 1
  2. RMB > Intersection
  3. Select Line 2
  4. Select Line 3
  5. RMB > Intersection
  6. Select Line 4
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
in reply to: mpatchus
Perfect!
