Hi there,
first of all look please look at the attachment
imagine a sheet (big black rectangle), then red rectangles are putted into corners
I want to have one subassembly - red rectangle with screw/bolt or whatever you call it, but i want to change position of screw if necessary (this screw needs to be a part of kit/subassembly)
but I do not want a situation when this new screw position is the only reason of making new subassembly
I tried Position in representation but I can assign constraints only to master level
any1 can help?
Solved by BarryZA. Go to Solution.
Hi!
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
I'll try IAssembly
but regarding first option: I will also try it but if the screw will be surpressed - will they be also counted in BOM ? (if so not - then ok, otherwise number of bolt will be double).
Maybe this is not as simple as it sounds to me.
But for Pos Reps. In the master position I create my first set of constraints. Supress those and create my second set of constraints.
Suppress THOSE and un-supress my first set.
then activate a Pos Rep and reverse i.e. supress the first set and un-supress the second.
it works perfectly for me with Iassembly but I don't like that Inventor creates SubFolder with different iam's configuration
BarryZA: how did you manage to use constraints in "NotMaster" position level? I am able to set up constraints only in Master Level
on other levels constraint option is not active
set up the constraints that you will need later in master position but then right-click supress. activate pos rep, right click constraint and un-tick "supress (override)"
between that and activate new pos rep- right click constraint "modify (override" change offset it does what I need to.
Hi!
Yes, it will be counted in the bom. It´s the easier process but you have to manage the bom and apply filters in the part list.
You can use the iAssembly and place the correct amount of screws and then Include/exclude constrains.
TIP: The better process to supress parts from assemblys and have a good BOM management is to use iLogic.
BarryZ: this is ok for me.
Carlos: also thank you for feedback, at least I used iAssembly for the first time with success
