I am attempting to add a material and the help says to select the "Design Tab" except my Ribbon has no such tap. What options are there to get to the material database if there is on Design Tab to select?
1. what version of Inventor are you using?
2. what is the url to the Help screen (or attach a screen capture) (you do not add a material from Design tab, so there must be some misunderstanding.
3. The Design tab is available when in assembly (*.iam) file.
4. attach your file here.
