iv2010suite
can someone tell me if it's possible to use custom parameters in the frame generator editing tools?
Example:
shorten a member by a length defined by a user parameter.
If not, then can it be done in 2012?
thanks ... chris h
You can check this article below. This might help to fix your problem.
http://beinginventive.typepad.com/being-inventive/frame-generator/
Vinod,
Thanks for responding.
Please tell me exactgly which article in the link you provided addresses my question.
I read the entire article and could not find anything relevant to my question.
Thanks ... Chris H
Hi Chris,
There was an article on adding custom parameters in FG. I was referring to it in our blog. Here is the video solution of the same. Is this what you are looking for in FG.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14127286&linkID=9242018
Vinod,
Thanks for reqponding.
No, that's not what I want to know.
Let me rephrase:
I want to use a User Parameter as the numeric value in the FG editing commands (same as when you use a User Parameter for the numeric value in an Extrusion or Cut or whatever).
Find attached a pic shoing what I mean.
... Chris
