Inventor Forum
curved bend in sheet metal part
6 REPLIES 6
Terry__Close
1018 Views, 6 Replies
Hi
Can a curved section with bend be applied to sheet metal part.I make extrusion for easier clarity.I am wanting to place the curved section (extrusion for demonstration purpose) with bend in sheet metal part but all created in the sheet metal environment.
Is this possible?
TC
6 REPLIES 6
JDMather
in reply to: Terry__Close
Use Contour Roll.
I would do the rolled feature first.
Terry__Close
OK
I did some searching and came up with the attempt attached.Have i done this correctly?
CAn this part now be flattened?
I do not use sheet metal that often but will make efforts to learn more
Terry
Terry__Close
pls see attached
can this part be flattened?
JDMather
I have not attempted your part yet, but after seeing your attempt I wish to revise my earlier statement.
Looks like if this is to work the Contour Roll should be created after the Face.
Terry__Close
JD did you attempt to model this please.Would like to see correct solution
Terry
Terry__Close
OK i have placed the Contour Roll after the face but still does not flatten.What am i doing wrong here?
Terry
