Inventor Forum
creating spring with adaptive length
4 REPLIES 4
priti_madhav
925 Views, 4 Replies
Hi
I want to create a spring with an adaptive length and I'm trying to follow the instructions on this site.
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=10120912&linkID=9242018
I also added such that the height of the spring can be animated by going into the Parameters.
Now when I put this spring into an assembly and I animate the spring in the Studio, I notice that the work plane that I created doesn't move along with the spring even though I've made it adapted. Could someone please help me and tell me what I might have done incorrectly. One thing I know is that I when I made the line (axis length of the coil), I couldn't find a way to constrain the line to the two work planes. Both ends of the line do touch the work planes.
4 REPLIES 4
JDMather
in reply to: priti_madhav
I don't think the person who wrote those instructions used the best technique.
Start a new part.
Create sketch line for axis from origin and dimension as desired initial Spring_Length =
Exit Sketch.
(You alread have one of the origin planes at the beginning of the line.)
Create the second plane by clicking on the line and the second enpoint of the line.
You should be able to figure out the rest. Post back if you get stuck.
priti_madhav
THANKS! That actually did help and it worked!
I have another question. Is there a way to make both planes move instead of the one?
JDMather
Sure, but I don't understand why you would want to complicate things.
Simply constraint the line midpoint to the origin and then create a userworkplane at each end.
ravikmb5
yes
Spring can length can be controlled by parameters
but i suggest
u just download the example file created by me
http://autodeskinventorusers.ning.com/forum
SPRING ANIMATION BY DRIVE CONSTRANITS
Edited by: ravikmb5 on Oct 12, 2009 4:32 PM
Please mark this response as Problem Solved if it answers your question.
Ravi Kumar MB,
i7 860 Dell Studio XPS Win 7 64 bit 12 Gb RAM & HP Z220 SFF Workstation
Autodesk Inventor Certified professional 2016
Email: ravikmb5@gmail.com
