Solved by mcgyvr. Go to Solution.
Assuming you are using the cable/harness module then sadly you can't fix its length..
I've requested this functionality many times before..
I'd love to be able to create a harness and simply be able to say "max length 12in" and then get an alert when you have routed it and it has exceeded that length.
Obviously you can check the length of a cable after its been routed but there is no real functionality other than that..
