Inventor Forum
creating a wire mesh
8 REPLIES 8
Message 1 of 9
leandrav
27989 Views, 8 Replies
Can anyone give me a solution as how best to go about creating a "wire mesh".
What i have tried is to create a solid flat (2mm thick) piece of material.
I then draw a diamond shape on the surface & extrude it so as to give me a void.
Then i use the rectangular pattern option.
The problem is that when i try putting in the amounts of the "holes" i need to brings up  message to use optomized compute.
I do that and then when i click to crate all the "holes" it comes up with a pattern failiure error.
What other way can i use to create my object.
8 REPLIES 8
Message 2 of 9
stephengibson76
in reply to: leandrav
depending on what you are doing it might be worth using a wire mesh texcture rather than trying to model it which will be really heavy in terms of computing
Stephen Gibson
View stephen gibson's profile on LinkedIn
Message 3 of 9
SeanFarr
You will want to use a texture, becasue creating a rectangular pattern of a cut-out will cause extreme lag in your system.
I found that the textures are scaled low, so they don't show up well, but follow this old post and it should help you get your result.
Old Post
Sean Farr
Product Designer at TESInc.ca
Inventor Professional 2014-Update 2 - AutoCAD Electrical 2014
Win7-x64 | ASUS P8Z77-V | i7 3770 -3.4 GHz | 32GB RAM |
240GB SSD | nVidia GTX 670 4GB - 320.49
Message 4 of 9
leandrav
in reply to: SeanFarr
Awesome!!! works beautifully
Thanks for the help guys!!
Message 5 of 9
BLHDrafting
Here is a more realistic Wire Mesh part. Just change the 4 User parameters to suit your needs. It's not overly taxing on the model. Can't remember where I found it but it's handy and you can 'bend' it.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
Message 6 of 9
leandrav
in reply to: BLHDrafting
I will give it a try. Thanks
Message 7 of 9
savich
Thanks, this works great!
Message 8 of 9
MelHoward8999
worked for me
Message 9 of 9
jaskiratVPK8U
This is really nice part. Thank you for sharing.
I have one more question. How did you put function in the description of the part. See the attached screenshot.
