Inventor Forum
create points.
2 REPLIES 2
rajeshindi
403 Views, 2 Replies
create points.
I need to create about 100 off points in a sketch.
I have the x and Y co-ordinates in a excel spread sheet.  Is there any simple way to create the points other than manually entering thru precise input.
Any help would be much appreciated.
Thanks.
2 REPLIES 2
MariaManuela
in reply to: rajeshindi
Create a new 2D sketch.
Go to Insert Points
Select XLS with XY coordinates
Go to Import Options to create automatically a a Line or Spline through points (if needed).
Asidek Consultant Specialist
www.asidek.es
rajeshindi
in reply to: MariaManuela
Thank you.
