Inventor Forum
crash information
7 REPLIES 7
Message 1 of 8
219 Views, 7 Replies
crash information
I've searched the newsgroup and the Autodesk knowledge base, and could
not find any relevant information on the following error.
' Crash Information
' ACCESS_VIOLATION
' Build: 275e, Release: 7 RTM - Date: Tue 04/09/2003
' Last command completed
' Last request completed
' Call Stack: Address = 11 utx.dll 0x0003232C utx.dll 0x00031830 utx.dll
0x0002A64B utx.dll 0x0002A605 utx.dll 0x00025888 rse.dll 0x000B231A FW.dll
0x0012CD3D FW.dll 0x00073669 FW.dll 0x00072716 MFC42u.DLL 0x00012566
KERNEL32.dll 0x00017D08
Could someone please tell me what this means.
Will
7 REPLIES 7
Message 2 of 8
Will,
The crash stack alone doesn't help much.
Can you post the dataset so that we can take a look at it?
Jason Ruge
Drawing Manager Tech Lead
Inventor QA
Autodesk, Inc.
"Will" wrote in message
news:58784BDDAAC7CE37B423A9C436A4A1DC@in.WebX.maYIadrTaRb...
> Hello,
> ' Crash Information
> ' ACCESS_VIOLATION
> Thanks,
> Will
Message 3 of 8
Jason,
Where do I find the dataset?
Will
"Jason Ruge (Autodesk)" wrote in message
news:C4E15966C0CEDE4C31C20E9ABC033FC7@in.WebX.maYIadrTaRb...
> Will,
> Regards,
> Jason Ruge
> Inventor QA
> Autodesk, Inc.
> > Hello,
could
> > ' Crash Information
> > ' ACCESS_VIOLATION
FW.dll
> > Thanks,
> > Will
Message 4 of 8
The dataset is the model / assembly you are working on.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
news:A02CDB76EB4B6C6B1EDDB512AAF3D060@in.WebX.maYIadrTaRb...
> Jason,
Message 5 of 8
The program crashes a few moments after starting it. The start up splash
screen will appear, and then it will crash.
Will
> Will,
> Regards,
> Jason Ruge
> Inventor QA
> Autodesk, Inc.
> > Hello,
could
> > ' Crash Information
> > ' ACCESS_VIOLATION
FW.dll
> > Thanks,
> > Will
Message 6 of 8
do you have an ATI video card? how much ram? system specs please......-Joe
Message 7 of 8
adaptec PCI ultra 160 scsi card
seagate 18 gig 10k 160 scsi Hard Drive
P4 1.6 ghz
Intel D850GB Motherboard
512mb rdram 800mhz (2 sticks)
win2k pro SP3
elsa gloria III 64mb ddr agp video
card
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
do
please......-Joe
Message 8 of 8
Stavros1000
Looks similar to the BSOD crashes I got when I recently installed INV7. Make sure all your system tray icons are shut off and there is nothing running in the background when you go to run INV. If you can then get INV to run, go straight away and set the video driver setting in the Application Options to something lower. Then you can test staility with other settings and try other troubleshooting methods. I have an ATI card and I can only run on the MS Generic driver because my card is not certified. After I made this change, my BSOD crashes seem to have stopped. Hope this helps.
Steve
