Hello
i have tryed the copy in another window and it works it brings the whole assebley over but i does not bring the part numbers over. it uses the description as the part number is there a way to fix this?
First - use Pack & Go. Don't forget to collect the drawings too. How to - was explained on this forum many a times.
Secondly - start Inventor and set you Project File to the one created by the Pack & Go function.
Then open Design Assistance and do re-naming of files in there.
When you are finished with the editing - close the Design Assistance and start open drawing files one by one. You will have to resolve the link for each of them by pointing into a new, re-named file.
After that you can move all the files into your working directory.
Best Regards,
Igor.
@Anonymous wrote:
now the conclusion of all this, does anyone know a good way to copy a design to a new folder and 2make it work" without using vault??
thanks,
john
If you first use the lower pane to find linked files (drawings, presentations, derive part base files, etc.) and change the Action to Update, these links will be updated by DA when renaming the files in the upper pane. No need for manual open and resolve link. However, the filenames of the drawings will have to be changed individually outside DA, if needed.
@IgorMir wrote:...
Yes, that's right, thanks Sam.
Needless to say that I didn't use that option myself. That's strange limitation with the renaming the file itself. Why not for drawings? Assembly and part files names can be edited... I will give it a shot anyway.
I don't think that the limitation is on the type of file, but that top-level files can't be renamed in DA. If you open DA from a subassembly, that subassembly can't be renamed in DA. In trying to figure out why that limitation exists, I guess that the subassembly example might explain it-- if you rename that subassembly in DA, it could be breaking links in higher-level assemblies that you aren't aware of. Purely speculation on my part, though.
DA is a useful tool, but it really needs a makeover to make it even more useful, more intuitive, and less annoying!
In the installed folder is a directory called SDK. Follow what the readme file says to install the user tools. Once installed you will find a directory called Copy Design which has a tool for copying designs and has the source code. You can edit the source with a free download of Vb.net and get it to rename etc as you want, or you can just use it as is.
I use it to copy all files to a new project directory, change the file name prefix and update all the links. It works great.
You can say that again!
@sbixler wrote:DA is a useful tool, but it really needs a makeover to make it even more useful, more intuitive, and less annoying!
Starting with A.iam & A.idw, copy both to B.iam & B.idw. Rename A.iam to xA.iam (temporarily), open B.idw. It cannot find A.iam, so it asks you to find it, you choose B.iam, save & close B.idw. Rename xA.iam back to A.iam.
