Inventor Forum
convert igs file to dwg
17 REPLIES 17
Message 1 of 18
horopallo
9847 Views, 17 Replies
Is it possible for someone convert an igs file to dwg for me?
17 REPLIES 17
Message 2 of 18
in reply to: horopallo
post the file... lets have a look
James
wrote in message news:5581282@discussion.autodesk.com...
Message 3 of 18
horopallo
here it is. thank you
Message 4 of 18
These ok for you?
James
wrote in message news:5581284@discussion.autodesk.com...
Message 5 of 18
horopallo
it works great! Thank you.
Message 6 of 18
no problem..
James
All I Did was:-
1. Open with Inventor
2. Save as SAT
3. Open with AutoCAD
4. Save as DWG..
wrote in message news:5581450@discussion.autodesk.com...
Message 7 of 18
> 2. Save as SAT
> 4. Save as DWG..
Autocat can import IGES files.
In the command line just type: igesin
I found no problem with that file.
M.
Message 8 of 18
JDMather
I think the OP has the vanilla AutoCAD - not the AIS or AIP AutoCAD. Vanilla AutoCAD does not have igesin.
The CADWhisperer YouTube Channel
Message 9 of 18
horopallo
Actually we are using AutoCAD LT which does not support igesin. I tried. Thank you for all of your assistance.
Message 10 of 18
JDMather
It is always helpful to provide information like this in the original post. I think you will find the people on this forum very helpful when a complete problem description along with a sample file representing the problem is supplied. Good to hear your problem was solved.
I haven't tried this but for future reference you might be able to convert an IGES yourself in the free Inventor LT http://labs.autodesk.com (limited availability) to ACIS and then use the acisin command. Otherwise just let us know and I'm sure someone here will help you out.
Message 11 of 18
gwsanford1
James:  I also have an igs file which I need converted to dwg format.  The file is posted herein.  Could you help me out by using Inventor to convert the file to dwg like you did for "horopallo"?  The file is 5.844M, which is too large for the 5.24M max to Post with this Message.  So if you could send me an E-Mail address or direct me to a file swap/transfer site, I could transmit it to you that way.  If you could help me out, I would really appreciate it...Thanks alot!  gwsanford1
Message 12 of 18
JDMather
in reply to: gwsanford1
You have replied to a thread that is 6.5 years old.
AutoCAD will import IGES directly now.
What version of AutoCAD are you using?
Message 13 of 18
gwsanford1
in reply to: JDMather
LT 2008....I don't think my version will do it, but how does the latest version do the conversion? Thanks...
George W. Sanford, P.E.
Sanford Engineering
607-5868
Sent from my iPhone
Message 14 of 18
JDMather
If you read response #10 in this thread - that is kind of important information.  You should include relevant information like this when asking someone to do work for you.  You are right - I don't think LT has the translators.
In the full version start a new file from appriate units template (inches or mm) and then click on the Insert tab and then click Import and set to Files of Type *.igs
You can download a free 30-day trial of Inventor, AutoCAD or Fusion 360 to do the conversion.  (I haven't checked Fusion 360 IGES import - dwg export, but if it does the translation - it can be rented for $25/mth if you have a continuing need.)
Message 15 of 18
janine23
can u also convert my files??? I needed it badly. THANK YOU
Message 16 of 18
JDMather
in reply to: janine23
I do not see any files?  What problem are you having converting your files (other than zipping and attaching them here)?
Message 17 of 18
sharadmahale
Dear James Lovell,
Can you please convert these IGS files to DWG formay for me?
It is IGS format only, I've changes the extension to dwg, as it was not uploading in IGS format
Thanks in advance
Sharad Mahale
Message 18 of 18
sharadmahale
in reply to: sharadmahale
I'm using AutoCAD 07
