Inventor Forum
constraint issue
2 REPLIES 2
keith_skidmore
229 Views, 2 Replies
constraint issue
Hello
While creating an assembly I will mate components together to a grounded component and the assembled parts are allowed to be moved and or rotated.
To get them back into position I need to click re-build.
Previously once you mated parts together I was unable to move or rotate them (they would become anchored)
Have I in-advertently changes a setting? And if so how do I get it back?
Thanks in advance
William K. Skidmore
White Conveyors Inc.
2 REPLIES 2
cwhetten
in reply to: keith_skidmore
Are you using the Move command to move them, or are you just dragging them?  The behavior you describe is normal behavior if you use Move to drag a component.  However, it is not normal behavior for simply dragging a fully constrained component.
Hi! It sounds like you might have turn on Defer Update in the assembly. Please go to Tools -> Application Options -> Assembly -> uncheck Defer Update.
If it does not help, please post the files you are having trouble with here or send them to me.
Thanks!
Software Test Engineer
