Please how do i get the spring to have a compressed look with flat end....i try different settings but not able to have the spring rings to touch for a compressed look
Regard
IJC
You should probably be modeling this as a IAM assembly file:
http://www.youtube.com/watch?v=O2XVbE26BNM
Thanks Blair
Good video
I will make this part as a IAM....i actually want the Spring in a static compressed position....i cannot get the rings though to touch as if the spring is compressed
IJC
Hello IJC, open the attached part and change the pitch of the coil. I split the coil profile in half. What value did you want for the pitch?
Glenn
Hi Chris
I am trying to follow your modelling...how did you split the coil in half...i do not see a split
IJC
Hi IJC,
I used the Center Point Arc command to draw two 180-degree circular arcs and then deleted the original full circle.
FYI, I'm attaching the Self-intersecting coils section of the What's New in Inventor 2014:
I'm curious to know what value you wanted for the pitch to "get the rings though to touch as if the spring is compressed".
Glenn
