Use natural, then all segments of rail whatever will lock together to form a
continuous rail.
You will have to use a formula/parameter to give you a vertical total height
input, though you could use extra features on either end to trim up the
vertical height carefully done you would not need a formula, but adds
features.
Actually the first method could be done with sketches either end to give you
a dimension as an input into the coil height................you will have to
think about that one.
Laurence,
Power is nothing without Control
"brian55" wrote in message
news:f188626.-1@WebX.maYIadrTaRb...
> Dear All
> Having a problem producing a coil of a rectangular section to form a
stringer section on a helical staircase.The main problem seems to be how to
define the coil ends (ie flat or natural).When I request the end to be flat
the depth of the section is measured vertically,when I req ends to be
natural the depth measures perpendicular to rake(this is what i
require)However the top of the section does not remain aligned with the
pitch line.
> Would very much appreciate any suggestions on how to approach problem.
> Regard
> Brain
