Inventor General Discussion
Distinguished Contributor
James__S
Message 1 of 16 (161 Views)
changing parameters
161 Views, 15 Replies
04-11-2014 07:43 PM
I have looked at the fx parameters as i want to change the Chamfer1 (fx.d5 & fx.d6) so that i can place a fillet on the nut....how do i decrease the face size so that i can use a small size fillet on the nut
JS
JDMather
Message 2 of 16 (138 Views)
Re: changing parameters
04-12-2014 03:59 AM in reply to: James__S
Set d5 and d6 to 95% of the face width value (or whatever percentage you need).
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
James__S
Message 3 of 16 (130 Views)
04-12-2014 04:58 AM in reply to: JDMather
Thank you for solution
Can both the Bolt and Nut have a real thread on the part rather then an appearance thread?
Is this possible?
Best Regards
James
Distinguished Mentor
mdavis22569
Message 4 of 16 (128 Views)
04-12-2014 05:02 AM in reply to: James__S
You can put in a real thread ... but if you're going to do it yourself ... check out a few websites to see if it's already down to save you time. McMaster Carr has a lot of 3d fasteners available that you can download that have the threads shown. Mike
Michael Davis
Charlotte, NC
James__S
Message 5 of 16 (121 Views)
04-12-2014 05:24 AM in reply to: mdavis22569
I wanted to see if i could learn the technique myself but i not sure how to start this.I think a coil feature would be one of the required tool but any suggestions on how to employ the technique of creating a real thread.
Cheers
JS
mdavis22569
Message 6 of 16 (118 Views)
04-12-2014 05:33 AM in reply to: James__S
here are a few ways via Youtube https://www.youtube.com/results?search_query=how+to+make+a+thread+cut+out+in+Inventor
Michael Davis
Charlotte, NC
JDMather
Message 7 of 16 (114 Views)
04-12-2014 05:35 AM in reply to: James__S
See attached
or
try Fusion 360.
James__S
Message 8 of 16 (103 Views)
04-12-2014 06:03 AM in reply to: JDMather
Bolt looks great
I am presuming the nut follows the same technique but will only require 1 coil feature
Thanks again
JDMather
Message 9 of 16 (97 Views)
04-12-2014 06:57 AM in reply to: James__S
Yes.
If you want more precise geometry (I have sharp V at OD (and at the root, but that is less of a concern)) consult your Machinery's Handbook.  Also, if you are going to 3D Print I chase a second thread offset a bit to increase clearance as the 3D Printing processes are not precise.
James__S
Message 10 of 16 (83 Views)
04-12-2014 07:58 AM in reply to: JDMather
I thought i would post back with the 2 examples.
Is this Nut thread correct to suit the Bolt?
How do i now constrain these so that they do not interfere with each other in assembly mode?
eg....The assembly attached is constrained but there is interference?
Maybe it cannot be used this way and cosmetic threads will be better
