Inventor Forum
chamfer won`t work
2 REPLIES 2
richard_cirillo
1664 Views, 2 Replies
chamfer won`t work
I am trying to place a 5mm chamfer along edge so as it meets the cylinder....i cannot get it to work on this model but on an exact other model i can place a 5mm chamfer...am i missing something here
thanks
Inventor 2013/Inventor 2014
2 REPLIES 2
Hi!
The question is; you have two different distances, and somehow, Inventor has issues split/merge the face between these two distances when you apply chanfer (between extrusion and revolve).
Workaround:
  1. Create the extrusion as a new solid (now you have two solids; multisolid part)
  2. Create the chanfer with the distance you need in the second solid: extrusion.
  3. Use "combine" to join the two solids... and that's it.
Check the attached part.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CCarreiras
Thank you Carlos
