Basically Laurence, the cam rollers (3) hold the weight of a threaded
closure 2181lbs, and a seal plate 808lbs, plus a tooling basket with parts
that may be 800lbs... the threads on the closure are 27" -1 modified
butress thread. the threads never come into contact with each other, the cam
rollers assure this. the pitch of the cam riser plate is machined to match
the threads of the closure.
The above assembly lowers into a pressure vessel threads on the closure
threading into the vessel as detailed above, then presure is introduced into
the vessel, 5000psi (tinkertoy stuff for us).
cool huh.. 🙂
"Laurence Yeandle" wrote in message
news:FF8C03D3B30F98126D54226418968E1A@in.WebX.maYIadrTaRb...
> I don't know how heavy duty the application is? If light you could get
away
> with straight rollers but heavy and the roller corners would score the cam
> face though possible with clearance on roller's bearing/ bush will allow
> tilting of roller to some degree. A light and small application and you
> would never notice. Sean's method for a constraint would be simpler than
my
> set up , don't see why it would not work.
> Laurence,
> Power is nothing without Control
> "Mark V" wrote in message
> news:95B76559237FE24E229928DD2853934B@in.WebX.maYIadrTaRb...
> > Yep.. I agree with the barrel shaped cam. In fact, thats the preffered
> cam
> > for this application. I have pointed this out to the engineering group
> here
> > a while ago, but there answer has been, well the old design works....
> > (20+yrs). So... I've put in the barrell cam, and no one is the wiser!
i'm
> > so sneaky... Anyhow, thanks fellas for the assistance!
