Hi
I have attached a screenshot of a bolt from the content centre....
1. What is the meaning of this dimension - fx:d59 = NLG
2. What is the meaning of this dimension - fx:Od2 = GD
Thanks for any clarification
would it be a list of named parameters?
Is there an advantage to naming the parameters...could many bolts be created from changing the sizes in the parameters dialog box?
Still learning
Yep. Those are named parameters.
The bolts (and other parts in content center) are created from a table of potential values, which are assigned to those parameter names. When you generate the CC part, it just plugs in the values from the table.
Rusty
