Inventor Forum
bend lines in export face
6 REPLIES 6
JimSteinmeyer
5182 Views, 6 Replies
When I use "export face as" to create a DXF file for our lazer table I loose the bend lines in the DXF. Is there a way to retain the lines in order to have the lazer scribe the bend lines for us?
Thank you
Jim
Inventor Premium 2013 SP1.1
Vault 2013- plain vanilla version
HP G71 notebook
celeron cpu w\ 4gb RAM and 64 bit system
Win 7 home premium
Ya, my boss has me running my personal machine at work.
6 REPLIES 6
Rigth-click over the Flat Pattern browser icon and choose Save Copy As (SAT; DXF or DWG)
Asidek Consultant Specialist
www.asidek.es
Maria,
When I exportede the file this way it not only gave me the bend lines but also included the lines on both sides of the bend and placed points at all intersections which would cause problems in the torch pattern. I did save it as a 2004 dxf. does it make a difference which year of dxf I use? I am usnig Inventor 2012.
Thank you
Jim
Jim
HP G71 notebook
Win 7 home premium
That lines on both sides of the bend are the Tangent Lines.
During Save Copy As you can set some parameters. Try put Off the visibility of some layers.
In the latter case you can always adjust the DXF file in Autocad.
www.asidek.es
Thank you,
For the life of me I couldn't think of the term for tangent lline.
Jim
HP G71 notebook
Win 7 home premium
Mark_Geurds
in reply to: JimSteinmeyer
Maybe a bit late, but this is what autodesk says:
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2015...
Hope it helps!
Moverano
Is there any way that instead of leaving the line, put a letter or words?
