BINGO Kim this is what I would call a bug!
Yes when you bring it in on a sketch in an IDW you can right click after a
window select and change the colors back to "standard" THEN copy / paste the
objects into a sketch in IPT. There is no Properties menu option in the
right click menu after a window select in the IPT sketch mode.
How do you log a bug?
"Kim Myers" <---> wrote in message
news:0EE5C66AB14885E0B0B5859BBC432790@in.WebX.maYIadrTaRb...
> I have noticed this too, and it appears to definatly be a bug. I know
this
> worked in 5.3. You can open your AutoCAD sketch into an .idw then copy
and
> paste into your .ipt sketch. This is a pain but your lines will change to
> black once constrained. Also if you change one of the AutoCAD lines to
> centerline or construction it will behave properly but not show correctly.
> Autodesk: Is this a bug that you know about?
> "Paul Harvey"
wrote in message
> news:64B517F010DED31800BA944DABA9E23C@in.WebX.maYIadrTaRb...
> > Bylayer and all lines are on layer 0. Layer 0 is set to it's default
color
> > (7). About the most basic set of lines that one could imagine. If it was
> > going to work right with any set of data, this would have been it.
> > "Dave J" wrote in message
> > news:7CD2F3E5AAC7D48DD383FE6EF6224F45@in.WebX.maYIadrTaRb...
> > > Is AutoCAD, is the line color ByLayer? or a set color?
> > > Dave Jacquemotte
> > > davej@autoconcorp.com
> > > "Paul Harvey" wrote in message
> > > news:9B6915089794E1C103F0A4618E34E64F@in.WebX.maYIadrTaRb...
> > > > Yes I have checked the "constrain end points" option. And thanks for
> the
> > tip
> > > > on the AutoDim tool; that seems to lock the thing down real good and
> > tight.
> > > > So I guess I don't care if it's constrained this time. But the
colored
> > lines
> > > > thing is still a mystery to me. It shouldn't oughta be that way.
> > > > "Kent Keller" wrote in message
> > > > news:1E2F593DA922028A0C81D327DAC66426@in.WebX.maYIadrTaRb...
> > > > > I don't do much with AutoCAD sketches but have you tried the
AutoDim
> > tool?
> > > > Also when you
> > > > > bring them in are you going though options and making sure the
> > endpoints
> > > > are constrained?
> > > > > Sorry no ideas on the color
> > > > > Kent
> > > > > Member of the Autodesk Discussion Forum Moderator Program
> > > > > news:F182BCD2C1AB59464295A820B803761F@in.WebX.maYIadrTaRb...
> > > > > > And another thing, is there a way to "resolve" the sketch so
that
> > > > obvious
> > > > > > constraints are applied automatically as the lines are brought
in.
> > > > Currently
> > > > > > there are absolutely no sketch constraints applied to these
> objects.
> > > > It's
> > > > > > quite a pain applying horizontal, vertical, tangent constraints
> > etcetera
> > > > > > (especially when there's no visual cue to tell you when you're
> > done).
> > > > > > Thanks in advance
