i have created a complex assemply which is consisted from many parts and other assemblies.
I want to create this main assemly in a scale 1: 4 and have these both assemblies together in a new assembly.
Is there any choice?
thank you
Solved by JDMather. Go to Solution.
I'm not sure I understand - but maybe Derive Component can give you what you are after.
Is this in the modeling/assembly enviroment or in drawing environment?
