Inventor General Discussion
Distinguished Contributor
warrentdo
Message 1 of 3 (392 Views)
apparent intersection not working
392 Views, 2 Replies
01-22-2013 01:39 AM
Is anyone having problems dimensioning to an apparent intersection in an IDW?
Once I hover over both lines to show the intersect and both line do intersect but it should turn green, it's not, it just keeps yellow.
It is placing the dim in the right place but it's also not drawing in the intersect lines.
It was working last month as I have a drawing to prove it.
This is on a few machines.
Also moving dimension is a problem. Sometimes they will not reattach after moving one end.
Not sure if this is related?
AIP2011 sp2
Cheers
Warren
*Pro
sbixler
Message 2 of 3 (382 Views)
Re: apparent intersection not working
01-22-2013 04:35 AM in reply to: warrentdo
I've never had a green indicator at the apparent intersection-- it's only when both extensions appear at the same time with the little yellow dot.  But I don't know why the extension lines are not appearing, unless the distances are too small.  Can you post an example drawing that we can experiment with?
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Member
MarianHelcman
Message 3 of 3 (380 Views)
01-22-2013 04:45 AM in reply to: warrentdo
Please look at attached video. Hope, it helps...
Marian
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
