Inventor Forum
agitator
9 REPLIES 9
Message 1 of 10
sam__gleeson
1175 Views, 9 Replies
agitator
I am after a agitator part if anyone have available.This goes on a shaft driven  by a electrical motor.
Sam
9 REPLIES 9
Message 2 of 10
JDMather
in reply to: sam__gleeson
Post screen shot or url of similar part.
Message 3 of 10
mpatchus
Here's a real quick one I made up.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 4 of 10
sam__gleeson
Thanks Mike
Here is a picture JD of a agitator
Best Regards
Sam
Message 5 of 10
mpatchus
Oh THAT kind of agitator!   LOL
Inventor 2025 Beta
Message 6 of 10
sam__gleeson
in reply to: mpatchus
Very nice Mike...that was quick...do you have something similiar where the blades are egg shape instead of the straight blades
Appreciated
Sam
Message 7 of 10
mpatchus
Sure, just used the same part and changed the way the LOFT is created.
Inventor 2025 Beta
Message 8 of 10
sam__gleeson
Hi Mike
fantastic...thanks for the models...i will now practice
Best Regards
Sam
Message 9 of 10
mpatchus
The straight bladed vane was created with two lofts.  One for the blade using two sketches for the blade profile, and another to connect the blade base to the hub, also using two sketches/profiles.
The curved bladed vane was created with one loft using the three sketches. I also added a fillet to round the end of the blade.
That's the only real difference.  If you compare the two part files you can see the process.  You can tweak the dimensions as required to achieve different results.
Inventor 2025 Beta
Message 10 of 10
sam__gleeson
Thanks Mike...very helpful
