Inventor Forum
adsk file format
35 REPLIES 35
Message 1 of 36
13010 Views, 35 Replies
adsk file format
Can anyone tell me anything about the adsk file extension which is to be coming out with inventor 2010?
What are its's capabilities, benefits?
35 REPLIES 35
Message 2 of 36
JDMather
What file extension? Can you be more specific?
Message 3 of 36
mcgyvr
someones been misinformed.
Message 4 of 36
Yes, I was in a meeting with an Autodesk Rep last week and while discussing the upcoming release of Inventor 2010 I asked if in the new release of both Inventor and REVIT it would be possible to import in REVIT native IPT files from inventor and keep the parametric intellegence.
He said...there will be a new adsk file format which will be more...."robust", ....that is all I know.
Message 5 of 36
The file extensions are the same, and no, they will not be
backward compatible, just like all the other modelers.
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
AIP 2008 SP3,
AIP 2009-SP1 PcCillin AV
HP zv5000  AMD64 2GB - Geforce Go 440, Driver:
.8185
XP Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
Message 6 of 36
*.ADSK is an exchange file format used in the AEC Exchange part of Inventor 2010 to get products out to Revit. In Revit the *.ADSK file format is used to author files for use in 3D Civil and so on.
Look up AEC exchange in the help for 2010 for more info.
Message 7 of 36
mflayler
The new .adsk extension is done through the AEC Exchange Application inside Inventor. The adsk provides more streamlined dumping to Revit Families.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 8 of 36
Sorry, forgot that one.... 🙂
Expert
Expert.
AIP 2008 SP3,
.8185
Message 9 of 36
As some stated, review the Help for AEC Exchange to
read about .ADSK files. This file format allows you to share Inventor data with
Revit MEP or AutoCAD MEP. The format includes the 3D solids, 2D views, AEC
Exchange connector information, and meta data. When opened in Revit or AutoCAD
MEP, that application only uses what is supported from that file.
If exchanging data with Revit or AutoCAD MEP, don't
forget to use shrinkwrap to simplify your data. It makes for smaller file sizes
and the MEP applications typically don't need the detail that Inventor
needs.
Hope this helps.
Patrick Miller
Autodesk Manufacturing Industry
Group
Technical Publications - Subject Matter Expert
Novi, MI
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Can
out with inventor 2010? What are its's capabilities,
benefits?
Message 10 of 36
I tested the file transfer in 2010. It appears that Revit
Structure 2010 x64 does not support the adsk format.
Expert
Expert.
AIP 2008 SP3,
.8185
Message 11 of 36
Here's the error message.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Manufacturing Implementation Certified Expert.
AIP 2008 SP3, AIP 2009-SP1 PcCillin AV
xp64 sp2,
Expert
Expert.
AIP 2008
Driver: .8185
Message 12 of 36
mflayler
When Patrick and I said Revit, what we meant was Revit MEP 🙂
Message 13 of 36
Correct its MEP only.
Patrick Miller
Group
Novi, MI
When
Message 14 of 36
Hi there!
Were are trying to open a ADSK file generated from Inventor in both Revit Architecture and MEP but we get the same message from both, "Revit cannot open .ADSK files that contain the building site workflow. Do you want to open the export report instead?". And we have tryed different options in Inventor but we must do something wrong...
What to do!!??
I attache the file we have tried if someone wants to try...
Message 15 of 36
The adsk file does not open in Revit MEP 2010 either. I
get the same error message as I did in Revit Structure 2010.
Expert
Expert.
AIP 2008 SP3,
AMD 64 x2 3.0 Ghz, 8GB RAM GeForce 9800GT 512MB
Message 16 of 36
I do not have Revit installed to try it. I will try
to find an answer for you. Until then, I'm wondering if there is an import
option as that is the intention - import the assembly into a building model. I
don't think it is a straight open operation.
Patrick Miller
Group
Novi, MI
Expert
Expert.
AIP 2008
512MB
Message 17 of 36
Here's a couple images that illustrate the issue.
The only function supporting the.adsk format is Open, as far as I can
tell.
xp64 sp2,
try to find an answer for you. Until then, I'm wondering if there is an import
Patrick Miller
Group
Novi, MI
I get the same error message as I did in Revit Structure 2010.
Expert
Expert.
AIP 2008
512MB
Message 18 of 36
Sorry for the long delay. I found that there
is a defect logged (1202491) and the hotfix should be released soon.
Unfortunately, there is no work around. Sorry for the
inconvience.
Patrick Miller
Manufacturing Industry Group
Expert
Novi, MI
tell.
xp64
sp2, XP Pro SP3, Windows XP Silver Theme
import option as that is the intention - import the assembly into a building
model. I don't think it is a straight open operation.
Patrick Miller
Group
Novi, MI
either. I get the same error message as I did in Revit Structure 2010.
Expert
Expert.
AIP 2008
512MB
Message 19 of 36
And here's the hotfix that I was told about. Please
report back if you have a chance to try this. Thanks!
Patrick Miller
Group
Novi, MI
there is a defect logged (1202491) and the hotfix should be released soon.
inconvience.
Patrick Miller
Expert
Novi, MI
issue. The only function supporting the.adsk format is Open, as far as I can
tell.
Expert
Expert.
AIP 2008
xp64 sp2, XP Pro SP3, Windows XP Silver
Theme
will try to find an answer for you. Until then, I'm wondering if there is
an import option as that is the intention - import the assembly into a
building model. I don't think it is a straight open
operation.
Patrick Miller
Group
Novi, MI
Expert
Expert.
AIP
9800GT 512MB
Message 20 of 36
Thanks for the respons!
We'll try this hotfix and report back as soon as my colleague is back from his vacation.
Stefan Lindberg
CAD-Quality Sweden
