Hi
what is the method used to create a electrical cord between these 2 connectors.I want the cord to have realistic look such as bends in the cord.I am afraid i do not know how to perform this procedure.Would someone care to show me how to make cord between 2 connectors.I am going to make a lot of these so this is good starting point to learn
Regards
Paul
Your tap drill size is much too large for the thread size.
Are you using Inventor Professional with Routed Systems?
If you are using Routed Systems - the first thing you will want to do is add a connector point to the part.
(See the Manage tab)
If not using Routed Systems - start a new part within the context of the assembly and then start a 3D sketch and Include Geometry the end circles of the connectors. Create a spline between the circles for a sweep path. You will probably want some helper lines at each end for tangencies.
I forgot to mention adding a Pin to the Connector before authoring (saving).
This is on the 3D model tab.
I created Cord-1 in assembly mode (make part)...i cannot get how to now make the electrical cord between the 2 connectors and Cord-1.
i need some help please making electrical cord in assembly mode.
i do not use the Routed systems
Thanks for any help
Paul
Paul,
This tutorial should get you started since you don't have routed systems.
https://dl.dropboxusercontent.com/u/9726802/Autodesk/introduction%20to%203d%20sketches.pdf
