Inventor Forum
adding electrical cord between 2 connectors
6 REPLIES 6
880 Views, 6 Replies
Hi
what is the method used to create a electrical cord between these 2 connectors.I want the cord to have realistic look such as bends in the cord.I am afraid i do not know how to perform this procedure.Would someone care to show me how to make cord between 2 connectors.I am going to make a lot of these so this is good starting point to learn
Regards
Paul
6 REPLIES 6
JDMather
Your tap drill size is much too large for the thread size.
Are you using Inventor Professional with Routed Systems?
JDMather
If you are using Routed Systems - the first thing you will want to do is add a connector point to the part.
(See the Manage tab)
If not using Routed Systems - start a new part within the context of the assembly and then start a 3D sketch and Include Geometry the end circles of the connectors.  Create a spline between the circles for a sweep path.  You will probably want some helper lines at each end for tangencies.
JDMather
in reply to: JDMather
I forgot to mention adding a Pin to the Connector before authoring (saving).
This is on the 3D model tab.
I created Cord-1 in assembly mode (make part)...i cannot get how to now make the electrical cord between the 2 connectors and Cord-1.
i need some help please making electrical cord in assembly mode.
i do not use the Routed systems
Thanks for any help
Paul
mcgyvr
Paul,
This tutorial should get you started since you don't have routed systems.
https://dl.dropboxusercontent.com/u/9726802/Autodesk/introduction%20to%203d%20sketches.pdf
gsmith9810
Paul, I suspect that McGyvr's tutorial is right-on (I haven't looked). In our shop, we don't "wire" our electrical components in the CAD system. Our engineers usually show a couple of inches of electrical coming out of the back of significant components. Often these cords end up in flexible wireways. Making the CAD model realistic/flexible is more trouble than its worth.
Without looking, I'd say the easiest way would be to create a 3D sketch to act as the sweep path and a 2nd sketch to act as the profile to sweep. More work but even simpler would be to create a part consisting of multiple, end-to-end connected 2D sweeps.
Remember, you are using this as a tool to make your life easier.
Gary Smith
Inventor Product Design Suite 2013sp2
Windows 7sp1 64-bit
nVidia Quadro 2000
