Inventor Forum
adding depth in a picture
6 REPLIES 6
martijnvremmerden
553 Views, 6 Replies
I'm a little stuck using Autodesk, I really want to have my logo engraved into a custom build project...
but the only thing I Know so far is how to add a image file, and how to engrave text.
is it possible to engrave a imagefile into a solid body (like text)
cya
6 REPLIES 6
im not sure if this is posible, can u post a photo of your logo?
is it hard to re-draw it in inventor so you can extrude it?
greets from holland!
Njiua
this is the logo
its not the most easy logo to draw in autocad or inventor, but i think there's no other way to get a closed sketch reddy for a extrusion.
so maybe someone els knows a way?
otherwise goodluck with drawing it!
-niels-
in reply to: martijnvremmerden
Welkom op het forum!
It's not possible to emboss an image file, you can only use those as decall.
Your logo doesn't seem too hard to trace, but you could also try using vector software (like illustrator, or the free Inkscape.) to do the tracing for you and saving the file as dwg/dxf.
Hope that helps.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
-niels-
in reply to: -niels-
I couldn't resist, took some cleanup to get it to work properly and the geometry will not be exactly the same but i hope you can use it.
Niels van der Veer
The Netherlands
martijnvremmerden
it worked, used inkscape to redraw it. It was easier than expected so I redisigned it for a bit
