I have some shapes in which i want to add solid color to sections.I cannot find anywhere to accomplish this effect.Can this be done in Inventor 2013..it will be a 2D view
Please view the attached 2013 file...can this be done
Rich
Solved by JDMather. Go to Solution.
If it is 2D - why aren't you creating the sketch in idw or dwg?
http://forums.autodesk.com/t5/AutoCAD-2013/symbols/td-p/3649346
I use Inventor much more then Autocad (new) so if possible would rat5her do in Inventor
Rich
If it is 2D - why aren't you creating the sketch in Inventor idw or Inventor dwg?
Sketched Symbols might be the way to go.
Thanks..
Yes you are correct....can the title block be removed from the bottom right hand corner
Rich
Yes.
Right mouse button in browser.
JD Thank you
1 final question....can the shapes be filled in with solid colors
Rich
Yes.
Hatch/Color Fill. (Fill/Hatch Region)
....and why do I doubt this is the final question?
