Inventor General Discussion
Valued Contributor
richard_cirillo
Message 1 of 9 (267 Views)
adding color
267 Views, 8 Replies
10-06-2012 02:50 PM
I have some shapes in which i want to add solid color to sections.I cannot find anywhere to accomplish this effect.Can this be done in Inventor 2013..it will be a 2D view
Please view the attached 2013 file...can this be done
Rich
JDMather
Message 2 of 9 (258 Views)
Re: adding color
10-06-2012 04:49 PM in reply to: richard_cirillo
If it is 2D - why aren't you creating the sketch in idw or dwg?
http://forums.autodesk.com/t5/AutoCAD-2013/symbols/td-p/3649346
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Contributor
richard_cirillo
Message 3 of 9 (247 Views)
Re: adding color
10-06-2012 06:34 PM in reply to: JDMather
I use Inventor much more then Autocad (new) so if possible would rat5her do in Inventor
Rich
JDMather
Message 4 of 9 (229 Views)
Re: adding color
10-07-2012 04:43 AM in reply to: richard_cirillo
If it is 2D - why aren't you creating the sketch in Inventor idw or Inventor dwg?
Sketched Symbols might be the way to go.
Valued Contributor
richard_cirillo
Message 5 of 9 (221 Views)
Re: adding color
10-07-2012 05:02 AM in reply to: richard_cirillo
Thanks..
Yes you are correct....can the title block be removed from the bottom right hand corner
Rich
JDMather
Message 6 of 9 (218 Views)
Re: adding color
10-07-2012 05:15 AM in reply to: richard_cirillo
Yes.
Right mouse button in browser.
Valued Contributor
richard_cirillo
Message 7 of 9 (215 Views)
Re: adding color
10-07-2012 05:19 AM in reply to: JDMather
JD Thank you
1 final question....can the shapes be filled in with solid colors
Rich
JDMather
Message 8 of 9 (213 Views)
Re: adding color
10-07-2012 05:22 AM in reply to: richard_cirillo
Yes.
Hatch/Color Fill.   (Fill/Hatch Region)
....and why do I doubt this is the final question?   :smileysurprised:
Valued Contributor
richard_cirillo
Message 9 of 9 (209 Views)
Re: adding color
10-07-2012 05:25 AM in reply to: JDMather
It is as i also just found it
Rich
