Gents,
The company I recently started at does not use project files or vault.
When I place a component into an assembly I get "The location of the selected file is not in the active project" everytime.
And I know this.
Project file is set to default and parts/assemblies are on different drives on a server.
Anyone know how to disable this prompt?
I can't find the option in the application options prompts tab, could be there, but there's alot of em.
Inv 2009.
Solved by ferrislb. Go to Solution.
Use a project file.... this is HIGHLY recommended. If your company doesn't want to use them (wow) then at least create one for yourself.
Wow is what I also said, but I am hardly in a position to change company policy, just being hired and all.
If I create one myself, the problem I have is that parts are on different drives, lol.
I suppose I will make one for each drive, I don't know, I forsee problems. Oh well.
I have a feeling if we switch to using vault, we will be remapping and renaming 6 years of parts.
Right click on 'Workspace' in the project editor and chose 'Add Path'.
Or alternatively, add your server based content as library paths to make them read only.
