I know this has been discussed in other threads but...Why is the YZ origin plane oriented this way by default? Having the plane oriented this way results in horizontal sketch geometry being vertical in the "right" (view cube) view. That's very frustrating! I thought this was going to change in 15 but it looks like they only made changes to the "look at" command which I do not use because it further complicates this issue. Thoughts? Solutions?
Solved by graemev. Go to Solution.
Solved by wimann. Go to Solution.
Sorry,
by default Inventor calculate it using its algorithm (depend what surface you pick and from witch side)
orientation in space can be tricky - then you decide your own "Horizontal"
uu
