Inventor Forum
Writing expressions in parametric dim.
4 REPLIES 4
258 Views, 4 Replies
I have a problem with writing expressions into dimensions in Inventor and
I'm wondering if anyone out there can help? I'm trying to round down a
number in a dimension: meaning if the value of d1=1.3, then d2=1.
I looked up in the help on how to do this and they say to use the "floor"
function. I tryed it and can't get it to work (Example: floor(83 / 2 in) ).
It won't accept it.
John Baranowski
HMS Products
4 REPLIES 4
floor returns a unitless expression so you'd need to say:
floor (83/2) * 1 in
see my site for a tutorial on Inventor functions
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
"John Baranowski" wrote in message
news:BD64674A43591449415E83FDC6AB04B6@in.WebX.maYIadrTaRb...
in) ).
> It won't accept it.
> Thanks,
> John Baranowski
> HMS Products
and you wonder why they taught you about the dimensions of equations in
school huh? it was so you could figure out how you have to manipulate your
results from equations in inventor to get it in the units you want!
surely there should be an option to over-ride the resultant dimensions of an
equation with the units you've selected for the parameter in question?
that's how i'd like it to work. say for example you have two lengths and you
want another value (also a length, for me that's mm) to be the result of a
division of the first two.
so your equation is d3 = d1 / d2 but this won't work because the result of
the right hand side of that equation is unitless, so you have to multiply it
by 1mm to get the right answer. i think that's silly and we should just be
able to over-ride the dimensions of the result (in this case ul) with the
selected dimensions of the parameter (in this case d3, and millimetres...)
*end rant*
col.
The function you are looking for in Inventor is
isolate(Number;SourceType;DestType)
In example, you want to have a linear dimension respond to a degree
rotation. Assume d1 is the angle in degrees and for one revolution of
d1, you want d2 to increase by 36 mm
isolate (d1;deg;ul) /10 ul * 1 mm (or something like that ).
Makes a bit more sense when you are changing betweens systems of
measurement which have no correlation at all (deg -> mm)
>*end rant*
>col.
Thanks for the info. It's seems crazy but I think I can handle it!
John Baranowski
HMS Products
"Charles Bliss" wrote in message
news:3DE5C170.2020207@cbliss.com...
your
an
you
a
of
it
be
millimetres...)
> >*end rant*
> >col.
