Inventor Forum
Working with styles and stanards...
7 REPLIES 7
Message 1 of 8
KF090
511 Views, 7 Replies
Is there something somewhere that explains how Styles and Standards work?
Example:  I create a new sheet metal rule, save it to the sheetmetal.ipt template, upload to Vault and everyone can then "Get" the latest template.  When I open an existing sheet metal part the new rules exist in the sheet metal defaults.  When everyone else create new parts they can see the new rules but when they open an existing part the new rules are not in the sheet metal defaults.  Why is this?
7 REPLIES 7
Message 2 of 8
mpatchus
in reply to: KF090
They should have to simply do a style update for the existing part.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 3 of 8
KF090
in reply to: mpatchus
That doesn't work for existing sheet metals parts.
Message 4 of 8
mcgyvr
in reply to: KF090
You need to use the "Save" button not the update button..
This will "save" that new style to your style/standard library.. (assuming you are all working from the same style/standard library)
Message 5 of 8
KF090
in reply to: mcgyvr
mcgyvr,
You mean it will "Save" the new styles from the template to your local library and thus will be available in existing parts then?
Message 6 of 8
mercerc
in reply to: KF090
Saving to your styles to a ipt template is limiting and you just outlined the limitation that it's only good for new sheet metal parts made from that template. It also congests your template with data you will not need  if you have multiple styles. A more broad approach it to create the sheet metal style and save it to your styles library this will make it accessible to all files old and new.
To do this first check your project file and in the listing “Use Style Library=” make sure it is “Read-Write”.
Next open a sheet metal file or your template and create a new sheet metal style. Once the style is created and added to the browser list on the left highlight it and RMB and select the “Save to Styles library” option.  You need not save the file as the style now resides in the styles library.
This saved the information to your Design Data folder and once it is saved old and new files can access the style library. Just make sure in the Styles editor you have your filter in the right upper corner set to “All Styles”
Since the version of Inventor you’re using wasn’t listed you may need to create new materials if they are not in the default material selection list. This has changed in the 2013 release.
Charlie M
Inventor Product Support Specialist
Message 7 of 8
KF090
in reply to: mercerc
Sorry, I'm running Inventor Pro 2014 SP2.
When I right click on the new style the "Save to Style Library" is greyed out.  The 'Use Style Library' is set to Read-Write.
Message 8 of 8
mercerc
in reply to: KF090
Try creating a new single user project file. Please remember to point it to the correct locations like your default one.
Charlie M
