In the attached, I have a 46' long pipe header with branches, check valves, fittings that run the length of it in 1' increments.
My question to the forum is, which would be the most efficient way in IV to do this assembly?? As of now, I am running everything through the T&P module because I like the control of the fitting orientation & dimensioning. Without spending too much time recreating the entire assembly again, would patterning these fittings throughout the length of the header be a better option??
Any advice is appreciated...
Thanks jletcher. I'm not too familar with iLogic at the moment, but if you suggest it, it may be worth a look at in this case. Haven't needed to go down that route before...
Look at some you tube videos you will be amazed what it can do 90% of the parts I do for clients are now ilogic..
