Inventor Forum
Work plane opacity adjustment???
5 REPLIES 5
timdown73
1051 Views, 5 Replies
Is there a way to do this in 14?  If not WHY NOT??
-Tim U.
Intel(R) Core(TM) i7-10875H CPU @ 2.30GHz 2.30 GHz>Memory: 32.0 GB Ram
Op Sys: Windows 10 professional
5 REPLIES 5
mdavis22569
in reply to: timdown73
I've never seen an option like that ...however you can submit it to Autodesk in the idea's forum http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232 The only things I can think of that you can do is On/Off/Resize
Mike Davis
timdown73
in reply to: mdavis22569
Thanks for the reply. I'll try submitting it if no one has already. Seems like something that could be easily added and is very necessary.
-Tim U.
mcgyvr
The ICE (Inventor color scheme editor) will allow you to adjust the transparency of the work planes front and back..
johnsonshiue
Hi! There is actually a way to change it. It is done via Registry setting. If you feel comfortable changing Registry settings. You can proceed further. Otherwise, it is better to leave them alone. Make sure you make a backup copy of the registry, so you can easily fall back.
The following key dictates how objects are colored by default with a given scheme.
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion18.0\System\Preferences\ColorSchemes\Schemes\
\001\ should be for "Deep Blue"
By changing "WorkPlaneBackColor" and "WorkPlaneColor" to 1,1,1,1, I am seeing the following on my machine.
Software Test Engineer
timdown73
in reply to: johnsonshiue
It's good to know there's a way to adjust them but getting into the registry is hardly practical and impossible on my computer here at work. This needs to be an options setting. Thanks all. I did submit it to the idea station. Please KUDOS if you agree. http://forums.autodesk.com/t5/Inventor-IdeaStation/Work-plane-opacity-adjustment/idc-p/4968766#M4676
-Tim U.
